AFE A15-4212031 DIESEL FUEL PUMP SYSTEMS AND FULL-TIME OPERATION
Our products are assured for reliability and durability which has high quality and standard. We always work towards to fulfill the requirements of our end users. Durable and reliable products at great prices You can shop for Auto Accessories suiting your budget and taste from our exclusive collection that includes top quality products to enhance the style comfort and functionality of your vehicle.
Supplied harness attaches directly to battery and utilizes Deutsch weather-proof connectors. No cutting or modifications of the stock fuel lines required. Vehicle can easily be returned to stock
Features- Clear high-impact polycarbonate sight glass for visual inspection of fuel
- Helical Spur Gears runs quieter than straight cut gears
- Contoured CNC manifold enhances flow
- Fuel pressure O. E. quality Viton Sealsgauge port
- Typical install is 2 hours
- Bronze gears more forgiving of contaminants than steel gears. The Helical spur gear design runs quieter than straight cut gears
- Eliminates porosity concerns with cast aluminum
- The DFS780 is powered by your ignition and can be run independently or in parallel with the stock fuel pump.
- The DFS780 spur gears ride on PEEK (Polyether Ether Ketone) bearing surfaces to reduce both noise and wear
Price: 1290.87
